Ir para o conteúdo principal
The Epson WorkForce 645 is an all-in-one office color inkjet printer. Model: C11CB86201.
Why won't it print in color
Will not print in color Black and grey only. HELP!
Esta é uma boa pergunta?
Pontuação 7
9 comentários
Hi,
Can you copy or scan in colour when using the printer's control panel?
If so, have you checked the printer properties in the computer that you are using to print from?
por
my printer won’t print a blue color only even if i scan a picture, it gets a problem in blue color only. can any help me what should i do ?
por
my epson L210 wont print color even i select colored in seetings
por
no matter what i do my epson will not print
por
Hi @etme45,
What is the model number of the printer if not a WF645?
Have you tried printing direct from the printer's control panel?
How old is the printer and has it worked OK before?
What have you tried?
por
Exibir mais 4 comentários
Adicionar um comentário
3 respostas
Pergunta mais útil
HI Thank you for your help I was desperate and called Epson. The ink I put in was new, so the tech had me go to maintenance #4 Ink Cartridge Replacement - to make sure the plastic cover over the ink was removed and the ink cartridge was installed correctly- , then #1 Nozzle check then #2 Head cleaning. I was told I may have to do the Nozzle check 3 times until the paper came out after doing a print check came out with solid lines of each colour with no spaces in between. Twice did it for me.
Esta resposta foi útil?
Pontuação 5
1 comentário:
Thanks a lot! Cleaning the Nozzle several times helped!
por
Check the print settings/preferences to make sure that Color Print is selected. Also check that the driver is correct for your printer and not a generic driver. The print job settings over write the printer settings, if the print job is set for B&W printing then the printer prints B&W.
Pontuação 2
It took 6 cleanings, but color started coming through. Thanks for the tip.
Pontuação 0
Adicionar a sua resposta
Debbie será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 10
Ao todo: 33,407
