Ir para o conteúdo principal
Seventh and final generation of the Cadillac Fleetwood / Rear Wheel Drive / 350 cu in. (5.7L) V8 Engine
13 Perguntas Visualizar todos
How to replace or repair broken motorized trunk retractor
Is it even possible to get this trunk to close automatically with a new or repaired motorized retractor?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Yes it is. it is possible
por
Adicionar um comentário
1 resposta
Solução escolhida
@boatbuildertom , Tom, Look for a broken wire for retractor at the trunk hinge drivers side, there is a plug there also may be loose/corroded plug or a couple broken wires.
Other causes could be fuse/relay, paddle/switch, actuator, pull down assy./motor faulty. It would also be a good idea to lube up the latch/lock assy. really well and note that the latch is indeed in the open position. Testing procedure can be found in the 1st link. 2nd and 3rd link are informative forums that also deal with same issue and have repair advice. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.cadillacforums.com/forums/cad...
http://www.cadillacforums.com/forums/rwd...
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Tom George será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 112
