Ir para o conteúdo principal
The second generation of the Mazda 3, also known as the Mazda3 and Mazda Axela, sedan and hatchback series by Mazda.
10 Perguntas Visualizar todos
Revs too high after service
After taking the car for a second service to reduce the revs I still find them higher than when I bought it. The mechanic said all he did was reset the computer. Is there a way I can change the computer settings or how would I go about changing the revs?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
countparas, You can not change the cars computer settings with out special scanner/software/knowledge as normally found at a dealership or well equipped shop.
Ask the dealer ship/shop to show you the cars idle speed specifications cold/warm(operating temp.), if idle speed is in the parameters should probably not adjust further. If not in parameters they should correct the issue. Whether by adjustment/faulty sensor, vacuum leak,throttle body sticking/dirty or having to change program in computer. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Esta resposta foi útil?
Pontuação 4
Your mechanic needs to set the rev limiter on the computer.
Pontuação 1
Adicionar a sua resposta
countparas será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 14
Duração total: 1,142
