Ir para o conteúdo principal
Proximity sensor iPhone6 plus
Hello Guys i have a question about my proximity sensor,
I replace my sensor to an other screen and its not workin properly anymore,
When i am making an call i use my finger to try to lock the screen and it works but when i hold in to my ear it some times go on lock sometimes it does not, can someone please help me out herr
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Usually I find out this is caused by a screen quality issue. The only fix I found was to use a better screen that would make the proximity sensor more sensitive and work properly.
Switching to a preassembled original screen will work too (If you can find an iCloud locked phone to use for parts).
Esta resposta foi útil?
Pontuação 3
1 comentário:
I have no proximity bracket placed on is that a problem? ,
In case not
is there annyway to fix this with a marker like the iphone4 ?? Or are the screens for the trash?
Or is there a possibility that i heaten the flex to long that its damaged?
por
Adicionar a sua resposta
glennjacobs será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 964
