Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
iPhone 5s home button bracket screws - how to unscrew
I can not get the iPhone 5s home button bracket off. I don't know if I'm using the wrong tool, 000 Phillips (purchased off ifixit), or it's just too tight.
The screws do not look like the traditional plus sign in a lot of the photos I've seen online.
Any ideas?
I'm also not sure how to upload photos on this so you all can see what I am dealing with.
Update (04/08/2017)
Could the screws be stripped?
Update (04/08/2017)
Here is a photo of what the screws look like.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Oh wow. Try a larger Phillips and a rubber band between the screw driver and the screw. If rubber band doesn't work a small piece of electrical tape has worked for me in the past.
por
Adicionar um comentário
2 respostas
Solução escolhida
I never use my 000 Kooku driver. It's real nice too. Shiny metallic purple. Rubber gaskets on the handle. Rotating head works much smoother. But it doesn't work. I use my 00 Best driver. Works every time. Does fail from time to time. Bought four of em in my day. Apparently they just straight up don't make a 00 driver over at Kooku
Esta resposta foi útil?
Pontuação 1
Hi,
I have done a lot of this particular repair. The 000 Phillips usually does the trick, however, in some instances where my customer has had their screen previously replaced by another repair shop sometimes I run into issues where that repair shop put different screws in. I don't know if this is due to lack of screw management or if it is that repair shops personal choice.
If it were the right screw you wouldn't have any trouble with it being too tight as the screws are too short to screw in too far to avoid damage to the front of the display.
Unfortunately, without knowing for sure I would guess that the issue is that incorrect screws are in the device. You might have to try several sized screw bits and hope for one of them to work.
Good luck.
Pontuação 0
Adicionar a sua resposta
HelpMe será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 725
