Ir para o conteúdo principal
The Canon PowerShot G11 is a point-and-shoot digital camera designed to be easy to use for photography enthusiasts.
14 Perguntas Visualizar todos
Dust Speck Inside Canon Powershot G11 Lens
I have what appears to be a dust spec on the inside of my Canon Powershot G11 lens and I want to disassemble, clean and reassemble. I took it to a shop that looked at it and they are 99% sure that it is not dead pixels in the sensor. They advised buying a new camera because repair would be $100's or find a used G11 without the dust speck and did lament that the G11 is a great camera, had a cult following and it was almost impossible to clean the innards.
Anyway if it is trash I might as well take a stab at cleaning it. Is there a manual that will guide me though the inner world of this cube packed with technology with a hope of being able to reassemble it?
Ed
Esta é uma boa pergunta?
Pontuação 1
3 comentários:
I found a Canon Service manual on here that looks like it has what I need.
por
@eddyv question answered, problem resolved? the manual going to work for you?
por
Old Turkey - Manual looks detailed enough; I will know better once I try to put it back together! :-)
por
Adicionar um comentário
2 respostas
Hello,
Do you have this canon service manual in order to help me to fix a defect on the lens
Regards
Philippe
Esta resposta foi útil?
Pontuação 0
1 comentário:
can you send me please so that i can try this at home. Thanks a lot Philippe
por
probably a sand inside the camera/lens, because i used it during when i sat down in the beach.
Pontuação 0
Adicionar a sua resposta
Ed van der Veen será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 698
