Absolutely no sound from Ipad 2
After battery, digitizer, and widi antenna replacement sound no longer works from headphone jack or speakers
Esta é uma boa pergunta?
Try cleaning the charging port, sometimes it gets oxidized and gives such fault. If you can replace it with a working one it would be even better.
Esta resposta foi útil?
I will try a new chare port
Unfortunately that did not seem to fix the issue. I ordered new speakers and headphone jack assembly
I'm a bit skeptical that will fix the issue, but there isn't much else left apart from a problem on the board itself. Hope you will succeed.
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 816
1 comentário
Did verify conn before putting digitizer on
por Bradley Crawford
