Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
Why is my ringtone playing, but screen doesnt show anything
Hello! Im having a quite serious problem with iPhone.
First i had iPhone 6+ and every time i do something with the phone (like scrolling facebook) and someone calls me, the ringtone starts to play and nothing shows on the screen. Im not able to press accept or decline call. I can press power button twice so it declines the call.
That was not good, and i bought a new phone. Iphone 5s (screen replaced)
The same thing happens now on that phone.
If you dont understand the problem, i can up a video of the problem.
Thank you!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Nichelmo, I have had this problem before. I'll tell you what's wrong and how to fix it.
It may be because you have been using your phone constantly without giving it a break or having your cell service storage run out...
First, try closing out of the phone app and reopen it.
Second, try restarting your phone.
Third, go to Settings - Display & Brightness - Raise to Wake.
If it's on turn it off, if it's off turn it on.
This worked for me. Let me know if it doesn't for you.
Esta resposta foi útil?
Pontuação 3
5 comentários:
Thank you! Worked great!
por
Worked for a few times, now it does it again.
por
All these sounds like the proximity sensor has gone bad or is blocked (bad aftermarket screens can cause proximity sensor to not work properly.)
por
How is that possible? Since when the phone is in my pocket and someone calls, i can answer it. But if i play clash of clans and someone calls me, i cant do a $@$*. Ringtone starts to play and i cant even see the caller on phone log.
por
I'm guessing the phone is getting too laggy to handle a game app to switch to phone call screen?
por
Adicionar a sua resposta
Nichelmo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 483
