Ir para o conteúdo principal
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
220 Perguntas Visualizar todos
Why do the Colors invert after replacing the LCD Screen?
I replaced an LCD on an iPad mini 1st gen. When you press on the screen toward the bottom, it switches to inverted colors. It also keeps prompting Siri. I believe it might need a new ribbon cable and home button. Any suggestions? Thank you.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
tripple-clicking your home button will invert the colours, and holding it will activate siri.
This could be a short in your flex, on the connector, or a mechanical pinch of the button.
-i would suggest removing the new screen, but keeping it plugged in. test the button with the screen apart from the frame. if this fixes the issue, it is a mechanical pinch, and you need to sort out how it fits in your frame.
-be sure you have taped the digitizer circuit across the bottom with electrical or Kapton Tape.
-make sure the home button slides nicely between the LCD And the Frame.
your home flex ribbon may be shorted, in which cas you will need to re-replace it
You could have the connector to the Motherboard having a loose pin. in which case you will either need to realign, or replace that connector.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thank you so much! I didn't know about taping the cable across the bottom, but it makes total sense.
por
pleasure to be of assistance. took my shop a few ipads to figure that out
por
Adicionar a sua resposta
Nathan Davenport será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 460
