Ir para o conteúdo principal
Earpiece volume stays the same after replacing to a new one
I have an annoying problem on my iPhone 6s Plus that I hear not so loud as I need to hear from the earpiece. So I ordered an earpiece online and replaced it my self...
After replacing to a new one - i couldn't hear anything from the earpiece and also the proximity sensor didn't work. So I contacted the seller and asked for a new one and I got a new one, replaced it - it started working again but, the same Volume as the original :(
So now I basically don't know what to do. Maybe order a new one or is it a problem on my motherboard...?
What do you suggest me to do?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
have you tried cleaning the mesh on the inside and outside of the screen. This could be whats causing the issue.
Esta resposta foi útil?
Pontuação 0
4 comentários:
Hmm... I did try to clean the mesh from the inside yeah. Is there a way to replace the mesh?
por
i ordered a new screen because my is broken,
does it come already with a new dust mesh?
por
Depends on who you ordered it from if varies with supplier i use mobiledefenders.com i know that all there parts do
por
Adicionar a sua resposta
liorgolan29 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 69
