Ir para o conteúdo principal
The GoPro Hero5 Black is an HD waterproof action camera released by GoPro in October of 2016. The 4k resolution video camera has voice control, a touch screen display, and built in WiFi.
Charging compartment door off camera
The door to the. Charging compartment
was pulled off the camera while removing the charging wire. No damage to door or camera. How can door be reattached to camera?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
William Waddell, I do not own this camera but my guess is, you may have to disassemble the camera enough so you can insert the charge port cover back into position(into the retainer). See link below on how to disassemble to access inside camera to enable port cover back in place. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
GoPro Hero5 Black Motherboard Replacement
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
William Waddell será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Ao todo: 181
