Ir para o conteúdo principal
The second iteration of Samsung Galaxy Tab tablet computers with a 7.0-inch screen. Model numbers: GT-P3105, GT-P3100, and GT-P3105.
125 Perguntas Visualizar todos
cannot start it even pressing on both buttons and not charging at all
tab 2 was on charge but when trying to start it won't start goes to android film ware but accidentally shut down and from that moment couldn't restart it at all .Please need help to solve this matter ,even please power button and volume up nothing happen
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Prinsley David, Try unplugging the battery for 5 minutes and then retry(1st link below). No go, then try a factory reset if able(doing so will lose all stored data). Reset info. from 2nd link below.
Press and hold the Power button until the Device options screen appears.
Select Power off.
Select OK.
Press and hold the Volume up button then press and hold the Power button.
When the Samsung logo appears, release all.
Select wipe data/factory reset. (Use the Volume buttons to highlight and the Power button to select.)
Select Yes -- delete all user data.
Select reboot system now.
Allow several minutes for the reboot process to complete.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Samsung Galaxy Tab 2 7.0 Battery Replacement
https://www.androidpit.com/forum/607041/...
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Prinsley David será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 80
