What screwdriver does the inside take?
I have the iPhone screwdriver but that doesn't work
Esta é uma boa pergunta?
@turtlj ,Turtl Johnson, From the partial disassembly link below, these are the screw types mentioned.
17 screws from the board using a T3 bit on your screw driver. Or, use a T4 bit if the screw is slightly stripped.
4 silver screws on the top and bottom are 4.0mm Phillips #00, and the 13 black screws around the sides are 3.0mm Phillips #00.
Using a T3 bit on your screw driver, remove the two 4.0mm screws from the metal bracket.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 14
Ao todo: 1,082
1 comentário
that's a pretty vague question.
do you have a picture of what youre talking about?
por Logixal Compartilhar
