Ir para o conteúdo principal
The Nikon Coolpix L32 is a digital camera that was released in 2015 by the Nikon Corporation.
does not open lens on turning on showing lens error
changed batteries and when button pressed lens error and nothing else
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
@walshm2177 , m walsh, If your camera just started doing this after replacing batteries, remove batteries and replace with a good quality set of new batteries and try. If the new batteries do not correct the issue, the lens may actually be stuck, requiring repair. Check the trouble shooting links below as they may help solve your issue. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://camerarepair.blogspot.ca/2007/12/...
http://www.steves-digicams.com/knowledge...
https://www.youtube.com/watch?v=AkEfnF6z...
https://www.nikonimgsupport.com/ni/NI_ar...
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
m walsh será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 164
