Not keeping the charge
Why is my gears s2 not holding the charge
Esta é uma boa pergunta?
erwinallamby, You can check the 1st 2 links to see if the info. helps gain back battery issue and if no help then faulty battery may be you issue.
If the smartwatch only powers on when connected to the charger regardless of charge time, then the battery is faulty. Replace the battery using last link guide.
https://us.community.samsung.com/t5/Wear...
Esta resposta foi útil?
I upvoted your answer ... however, if you have a link for a GOOD replacement battery for the Gear S2 Classic, I would appreciate that.
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 20
Ao todo: 4,575
1 comentário
My gear 2 isn't holding a charge all day, what can I do?
por dpkelly54
