How can I reset my ProScan PLT 8801 K tablet
Esta é uma boa pergunta?
If you can get into the tablet:
1.Click/Tap the settings
2.Choose the privacy
3.Click/tap the reset phone
4. Select Erase Everything
5.After that your device will be wiped and it will be a factory fresh state
6.From the home screen,tap the menu
7. Select settings
8.Select Reset and back up
9.Choose factory data reset
10.Tap Reset device
If you cannot get into the device
1. Turn off your tablet
2. Press Volume Up + Power Button + Home
3. Recovery Menu would be up by now
4. Scroll down and Find " Wipe Data/ Factory Reset"
5. Click next , Scroll down until you find " Yes-- Delete all data "
6. Confirm and Reboot your tablet.
7. on a reset you will need to enter the password for your google account that was used to login originally on the tablet
Esta resposta foi útil?
when the device is off press power button and one of the volume buttons then you will see proscan.
a menu should come up with some option use volume buttons to go up or down use power button to select.
choose factory rest
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 13
Ao todo: 2,674
5 comentários
I did that. factory reset Rebooted
Now my tablet just flashes proscan android .. Can't use it now. How do I fix it ?
por Marty Mart Compartilhar
I factory reset it several times and it still keeps flashing proscan android.. What do I do ?
Can't get into tablet. . Just flashes over and over. I factory reset it about 10 times. Screen pops up. I scroll down ..hit wipe clean reset ..then I reboot it .. Same thing..
Just flashes
How can I boost the speed of this tablet. Please can you tell me
por Adnan Jalal Compartilhar
I cannot get my PROSCAN PLT8801K to connect to the internet
por Robert Turner Compartilhar
