My h/lamps won,t comeon
the headlamps on my 2000 4-runner, due not come on.
high beams an p/lamps all work
fuses are good
Esta é uma boa pergunta?
fuses are good
rdmattia , check/test both bulbs(totally possible for them both to be blown out), check wires/sockets/plugs for corrosion/damage/loose,dimmer relay, faulty switch(test), More info. at the link below. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 82
