Ir para o conteúdo principal
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 Perguntas Visualizar todos
In boot loop 5 or 6 times then goes black
Hi Guys.
OK i have a Samsung Galaxy S5 which has never had a screen replaced or ever been damaged.
When it was brought in it was just a blank screen the phone is on as i can hear when it rings gets messages ETC it also vibrates too.
I took the battery off so i could restart it it does start up & comes up with the Samsung Galaxy S5 start up graphic then loops sometimes 5 times sometimes 6 then the screen goes black.
When the screen goes black the buttons along the bottom light up fine when activated.
I can't tell if the backlight is on when its black i don't think it is.
Any help or suggestions would be greatly appreciated.
Thanks in advance.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Hey Kenny, Ive run into the issue before ive found a temporary fix but it only works long enough to pull data off the phone the phone is pretty much screwed
Ive found that heating the proccessor with a heater for 8 minutes at 120C make sure you place the heat gun 3 inches above the chip and heat let cool and reassemble this has worked for me 90% of the time and will pull it out of boot loop for about a hour
Esta resposta foi útil?
Pontuação 1
1 comentário:
Hi Stephen thank you i will give that a go later & let you know how it goes.
por
It sounds like an issue with Android itself, it might be soft bricked. Did you try to flash/install something?
Pontuação 0
2 comentários:
Don't think so she said she has never had anything done to it
por
Reading it over now, I see what you mean. Sorry, I must've misread the question!
por
Adicionar a sua resposta
Kenny Leonard será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 14
Duração total: 90
