older screen on a newer body (inverter to logic board cable help)
Hello.
I was recently given a MacBook Pro 15" Core 2 Duo Model: A1260 with a broken screen.
I already have a Macbook Pro 15" Core Duo Model: A1150
I decided to see if i could put the A1150 screen on the A1260.
The result is that everything fits except the inverter to logic board cable has a different wire configuration and logic board connector. The inverter side appears to be the same (aside from the different wire configuration).
Can i use the A1260's inverter cable with the A1150's inverter? I believe it will fit but the wires will be in a different orientation. Does this matter?
I'm hoping i used all the right terminology.
Thank you very much for any advice.
Esta é uma boa pergunta?
1 comentário
Could someone be so kind as to tell me the output volts of each pin from the Logic Board of a A1150 and a A1260. if they are the same i can fashion a cable.
Thank you
por Ben
