Ir para o conteúdo principal
Lançado em junho de 2012, modelo A1278. Processador Intel com Turbo Boost, até 512 MB DDR5 de RAM vídeo
1624 Perguntas Visualizar todos
Will not turn on after attempting to change backlight fuse
Hello,
First, my screen was black with a flashlight showing the computer was on. I determined the back light fuse was blown. When I tried to desolder it, I shorted to nearby component. The motherboard was not unplugged from battery.
Now, absolutely nothing happens when I press the power button. Can anyone you please point me to where the problem is likely to be now?
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Uh, Charles...there's usually a _reason_ fuses blow. Their purpose is to save power supplies and upstream components. Therefore, there was probably a short circuit downstream from the fuse to begin with. Failing to remove power from the unit before applying a soldering tool was a _major_ malfunction! At this point, the problem could be a blown component / circuit trace anywhere in the system! Good luck...
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Charles Kensington será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 80
