Ir para o conteúdo principal
Fingerprint issue in setup
Please see the following pictures.
Fingerprint works in certain parts of the setup.
Any solution?
I did restore the software.
Esta é uma boa pergunta?
Pontuação 1
8 comentários:
Could you please explain the question a little better. Maybe I can help you
por
Ok so my iPhone 6S Plus old screen was working fine but sometimes was flickering around the corners, so I decided to change my screen like I did myself because I'm a technician so I tried around 5 screens and I realized those screen were not good quality so today I got another screen so the fingerprint was unable so I disconnect the screen and connected again and works so I went to fingerprint setup to add a fingerprint and it works but in order to complete the setup the next page was blank as you can see the pictures.
Any solution?
por
@albertoh did you do anything else besides opening your phone and trying to setup the fingerprint? I mean hard reset or something else.
por
Have you Recover the iPhone through recovery mode.
NOT settings reset ?
por
If not, I can tell you how to enter recovery mode
por
Exibir mais 3 comentários
Adicionar um comentário
1 resposta
how to fix fingerprint gray out on iphone 6?
Esta resposta foi útil?
Pontuação 0
1 comentário:
Try to replace home button extension flex cable, but use the original home button or it will never work.
por
Adicionar a sua resposta
alberto houtmann será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 18
Ao todo: 157
