Ir para o conteúdo principal
A laptop computer by Samsung, identifiable by the model number NP-RF411, released in 2011.
2 Perguntas Visualizar todos
My laptop turns on but no image on the screen
I need help with my laptop Samsung RF411. It turns on, ligthts come up, but the screen is dark. I've tried to plug an external monitor but without any effects, still nothing on the screen. Any ideas?
Esta é uma boa pergunta?
Pontuação 1
2 comentários
I am here because I have the (same) experience with a RF511, although the question is not detailed. A friend has given the laptop to me, after being left in a cupboard for years. After switching on, there is no disk activity, and the screen doesn't even flicker. I suspect the CMOS battery is dead, but was hoping to see if anybody else had the 'exact' same problem (with a resolution)
por
if you got another computer go to major geeks download a all windows boot disk put in your laptop turn it on. it should do repair works for all computers …. did you try removing the battery, count to 10 with your finger on the power button. plug it in and power it on if not put the battery back in and try the same solution hope these both help you all
por
Adicionar um comentário
1 resposta
Solução escolhida
If no image appears on the external monitor you're likely left with a video card issue. Your laptop has integrated video so it is not a replaceable card, you'd be looking at replacing the board. Considering that there are no images at any time it is likely that your data is still intact and can be recovered by removing the hard drive and placing it in an enclosure or a dock and connecting to another computer.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Alex Sander será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 1,074
