Ir para o conteúdo principal
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
382 Perguntas Visualizar todos
Bluetooth shut down. BT not available
Hi People! How are you?
The bluetooth on my new 27" i5 iMac shut down. The keyboard
and mouse stopped working. If I connect a USB keyboard
/mouse - that works.
The Bluetooth icon in the top menu bar has a ~ through it.
Clicking on it shows Bluetooth: not available.
"No information found" if I click on Bluetooth in the System
Profiler.
No bluetooth in the System Preferences pane.
I pulled the plug on the iMac and restarted it and it worked
again. But Im still weary. My Mac experience is now tarnished ;-)
Is this a HW or SW problem? I hope SW
Thanks for an answer!
Update
I have 10 + Years of PC experience. I work in a tech environment. I am tech savy. The batteries should really not be the problem. I'm not one of those non tech capable Mac users. But paying 2000 € for a computer brings with it some expectations...
I just hope it's a SW issue
Esta é uma boa pergunta?
Pontuação -1
1 comentário
First rule of computer diagnostics: Check all the cables! In a wireless environment that would be batteries. We get all kinds of DIYrs here, and without you stating you'd checked the batteries, I have no way knowing your experience level. Sometimes the simplest thing IS the solution. N
por
Adicionar um comentário
2 respostas
Solução escolhida
Seems like a lot of people are having this issue. Make sure you have the latest software updates. Take out AppleCare before your warranty expires and read the discussions on it and subscribe to these forums.
http://forums.macrumors.com/showthread.p...
http://discussions.apple.com/thread.jspa...
Esta resposta foi útil?
Pontuação 2
Pergunta mais útil
Put new
batteries in the keyboard and mouse.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
Pontuação 2
Adicionar a sua resposta
Roman Woznik será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 8,090
