Ir para o conteúdo principal
Receptor GPS de bolso com tela sensível ao toque de 4,3" e Bluetooth.
It's not turning on
I have previously replace the battery front screen and updated the maps & it was working fine, but for some reason it won't power on. Left it on charge but it seems like the charge may not be registering with inside battery. I can see the green light on but nothing coming on. I left the device working in the glove compartment of my car so not sure what's wrong?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Raja Minhas , If you are not sure the device is taking a charge try another compatible charger to see if that is the issue. If charger is good remove the battery(1st link)below and see if it is fully charged use a DVOM, if battery not charged could be a faulty battery or charge port issue. Blow/pick out any dust/lint/etc. from the charge port and look for bent pins and straighten carefully with a tooth pick. If battery is OK and charged try a reset 2nd link will tell how. If device happens to be under warranty return for repair/replacement/refund. Good luck.
https://www.youtube.com/watch?v=NcbebExQ...
https://www.gpspower.net/tomtom-tutorial...
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Raja Minhas será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 579
