Ir para o conteúdo principal
2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
265 Perguntas Visualizar todos
Battery not connecting properly after reconnection
I have replaced my A1425's retina screen assembly and, after reconnecting the battery (everything's in place, no issues with interposer) it's not being recognised. I cannot start the mac without AC power and the battery menu calls for replacement. I suspect the battery is misconnected or the cables damaged. How would you troubleshoot this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi!
Did you solve the issue? If not, did you try resetting the SMC?
Hope that helps!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Augusto Gesualdi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 72
