Ir para o conteúdo principal
Repair and disassembly guides for Samsung printers.
Samsung C1860 is tinting everything yellow.
I have had my Samsung C1860 MFC Printer for about a year now. Recently I have noticed degradation in print quality and of late everything I print is tinted yellow. So blues are green, reds are orange/red and black are... I am not sure what color you call that but it is not black. I printed a test page from Windows 10 to make sure it wasn't the program I was using to print and it isn't its the printer.
Esta é uma boa pergunta?
Pontuação 1
5 comentários
When was the last time you replaced the toner?
por
I just replaced the toner because of this issue.
por
How would you fix it if you knew how to?
por
two months before and now every paper printing coming yellow shed
por
print every paper yellowish I do not know why
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Barry Hoven , Uninstall your printers driver and reinstall, in case it had been corrupted. You could also try resetting the printer, instructions link below, to see if that corrects the issue. Good luck.
http://support-us.samsung.com/cyber/popu...
Esta resposta foi útil?
Pontuação 3
1 comentário:
That is a really smart idea. I will try that!
por
I had this problem too, with my Canon printer. You could check your ink cartridges and look for yellow in blue, etc. If you have a refillable tank, refill it with the color that is the color of the cartridge. If a non- refillable tank, replace it with the same color of the cartridge.
Pontuação 0
Adicionar a sua resposta
Barry Hoven será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 2,347
