Ir para o conteúdo principal
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Perguntas Visualizar todos
water damaged iPod touch 4g
My sons 2nd ipod wash...unit has power and touch screen responds but it is difficult to see whats on the screen. Would replacing lcd possibly work for this?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Pergunta mais útil
Dont waste your time on a new LCD, it wont help. The 6R8 backlight coil is the problem, try disassembling using the guide on here, then on the logic board look for a round looking chip that has 6R8 on it. Clean it(and the entire logic board where ever you see corrosion) really good with a soft toothbrush, distilled water, and dish soap. Let dry for a few days, I usually wait 3 to make sure all the water is gone. Reassemble, if it still isn't working you'll need a new one - requires soldering but can be replaced.
Esta resposta foi útil?
Pontuação 2
It may just be the connection between the screen and the board. My son left his outside, in the rain, while we were on vacation. I tried rice and baking it at 220 F, but that didn't work. I took it apart and put it back together and it worked.
Pontuação 0
Adicionar a sua resposta
Nicole será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 4,515
