Can I replace the front screen?
I have many cracks and scratches on screen which appears to be a cover screen, can I replace it by peeling off the old one?
Esta é uma boa pergunta?
@maryflamingo , Mary, If it is just one of those aftermarket screen protectors then yes you can peel it off. If it is the actual digitizer for under twenty dollars you may want to consider replacing the whole screen assy. 1st Link below shows how to disassemble the phone to enable replacement of the screen assy. and 2nd link to replacement screen assy. Good luck.
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 146
