Ir para o conteúdo principal
Repair information for the Fitbit Charge HR. Released in January of 2015. Model numbers: FB405BKS (small) and FB405BKL (large).
Can this be fixed
The middle of my Fitbit (below the screen) had started to separate with the watch. If I push it back in it will soon pop out again. The watch itself is still fully functional but I'm worried that the watch will get more damaged if I carry on running with it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@adam2208 ,Adam, If watch still under warranty, have repaired under warranty by manufacturer. Even if not under warranty use the link below to contact Fitbit and see what they can do for you, ask for a resolution manager if need be. Good luck.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Adam levin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 114
