Ir para o conteúdo principal
2.3L 4cyl or 3.0L V6, 6th Generation
Check engine warning light
What would cause the check engine warning light to come on?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@dean7125,Rodney, Something as simple as a loose gas cap could cause the light to come on. Normally an emission related fault, but could be other. Best to have the error codes read to see what the fault is with out guessing. Some of the auto parts suppliers offer free code reading like Pepboys, Nappa, Advanced auto parts,etc and some of the guys are very knowledgeable and may have seen the issue often and put you on the right track. You can also use the link below to see how to retrieve the trouble codes your self. Good luck.
https://www.youtube.com/watch?v=bkKCkS-T...
https://www.youtube.com/watch?v=8M5BaAa6...
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Rodney Little será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 130
