Ir para o conteúdo principal
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 Perguntas Visualizar todos
"Back" and "Options" buttons are not responding.
Hello, I had to completely replace the screen on my Galaxy S4 T-Mobile version, so I was following a video tutorial from iFixit.com. After completing the procedure, the screen itself shows everything and works perfectly, but the 2 touch buttons (to the left and to the right of the main physical button) are not responding. Can someone please suggest a solution for fixing this, and what could have gone wrong? Thanks ahead!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
Turns out that the little "flex" cable, had a thin layer of plastic (right below its connector) that had to be removed. I also updated the touch buttons firmware, by opening the phone's Keypad and typing in "*#2663#", and then clicking "Touch Key FW update" option. After all this, my phone seems to operate properly again!
Esta resposta foi útil?
Pontuação 0
try to restart your device, or the button is probably malfunctioning.
Pontuação 0
1 comentário:
That was the first thing I tried, but it didn't help.
por
Maybe you somehow damage their connections. Try to open it and see if you can find any problem.
Pontuação 0
Adicionar a sua resposta
Sveatoslav Gleanco será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 500
