Ir para o conteúdo principal
The Google Pixel is Google's first flagship phone, released on October 20, 2016. The 5-inch AMOLED display device comes with 32 and 128 GB storage options and is available in three colors; Very Silver, Quite Black, and Really Blue.
102 Perguntas Visualizar todos
No sound on video shooting
No audio sound while playing a video captured using the phone camera, a muffling sound comes ! Microphone is perfectly fine as all other things are working well regarding nicrophone, i even tried shooting through whatsapp camera app and snapchat app but same results !
Esta é uma boa pergunta?
Pontuação 1
2 comentários
what phone? have you installed any new apps?
por
Google pixel and no haven't installed any new apps ! I even booted my phone in safe mode, the problem still occurs .
por
Adicionar um comentário
3 respostas
Pergunta mais útil
Try a factory reset, it sounds like a software problem. If that doesn't fix it go to google, they might be able to help. If not get a iPhone
Esta resposta foi útil?
Pontuação 2
Google Pixel has three different microphones. The main one located next to the USB-C charging port is used for making calls and voice commands. The "camcorder mic" is independant, so perhaps it is malfunctioning (Google is replacing phones because of this, is a known factory issue).
Did you try sending the video to another device and watch it there? Is the video without audio or your device fails to play the audio of that video in particular?
Pontuação 1
This is a known issue with a weak solder joint on the Audio codec chip. A reflow of the chip will usually work, sometimes a reball maybe needed. Google are aware of this issue and were offering replacements last year to those effected. If you need more info let us know.
Pontuação 0
2 comentários:
Could you do a follow-up post with a diagram of where the chip happens to be, and how we can go about reflowing it?
por
HOw do I retrieve the audio from the video. Can I still reach out to google to get the replacement?
por
Adicionar a sua resposta
Ruchir será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 21
Duração total: 2,928
