How do I remove internal D pillar trm
to replace rear seatbelt
Esta é uma boa pergunta?
@jethro49er, Terry, Normally they have clips just like the others. I used a V-pry/ long screw driver and a flashlight to locate the clips from behind. Use the screw driver to apply pressure. It keeps the clips from breaking off. The 1st link to manual below may help, 2nd link is the different D piller trim you may be able to see the clips,etc. Good luck.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 119
1 comentário
@jethro49er what year is your Range Rover
por oldturkey03
