Ir para o conteúdo principal
The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
271 Perguntas Visualizar todos
Galaxy Note 5 Wi-Fi and Bluetooth not working
My Samsung Galaxy Note 5 has problem with Wi-Fi and Bluetooth. Neither of them turns ON
I reset the device and didn’t work
The symptoms are: the Wi-Fi slide is OFF and grey, when sliding it to ON position it displays message “Wi-Fi Turning ON…” for few minutes and then it goes back to OFF; the same is with Bluetooth slide. I opened it to see if any wires were loose. All seems normal and all other functions of the device work fine.
Is it possible that the Wifi-Bluetooth modules are fried?
It looks like they are part of the mainboard. Can you suggest a diagnostic tools to determine if it’s in fact a hardware problem so I may start chasing the replacement part?
Thanks
Esta é uma boa pergunta?
Pontuação 1
2 comentários
I think the microchip of wifi/bluetooth should replace it
por
I accidentally dropped my Samsung Galaxy Note 5 and then the wifi and Bluetooth won't turn on anymore. What seems to be the problem? Can this be fixed?
por
Adicionar um comentário
1 resposta
Solução escolhida
solution? . . . . . . . . .
Esta resposta foi útil?
Pontuação 0
1 comentário:
Does the phone have the latest update installed?
Also, did this just start happening or has it been doing this for a while?
por
Adicionar a sua resposta
Omar Zn será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 1,582
