Ir para o conteúdo principal
Monochrome laser printer introduced in 2012. The printer is rated for 35 PPM and the first page comes out in 8 seconds. Depending on which model you own (a/n/dw/dn/dne), you will have different options and available features. Uses HP 80A/80X toner cartridges.
Will not turn on
The printer was working a few hours ago and then turned off. I have checked the power supply and cord to the printer and these are fine. The printer did come back on for about 45 seconds, after I removed the power cord and waited for a few minutes. However after that one time, it has not come back on even doing what was first tried. Is there a fuse on reset button inside? Thank you
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Thank you! It is working again.
por
Adicionar um comentário
1 resposta
Solução escolhida
HP's suggestion is to turn the printer off for a half hour and turn it on. If it is still having problems then contact HP tech support. If this is still in warranty they may replace it.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Dale Devenport será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 35
Ao todo: 3,111
