Ir para o conteúdo principal
iPhone 5 shutting down
So alike to my 5s, my iphone 5 is having the exact same problem (batt died, didn't change it till about halve a year later), its shutting down by itself when not in use, what's different is that there are lots of panic code in the diagnostic.
Problem:
Phone keeps shutting down when not in use, changing battery doesn't solve the problem.
Question:
Which IC is broken? Or what else could it be?
PS.
Reset, restore did nothing, also tried removing the proximity.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
4 respostas
Pergunta mais útil
Power management IC no doubt. U2 Tristar Charging IC does not cause this.
Esta resposta foi útil?
Pontuação 2
4 comentários:
I have an iphone 5 with the same prob, so U2 of both phones busted?
por
It's not U2 it's PM IC.
por
If the main power ic is busted it won't even turn on right?
por
No because I have a iPhone 6 with this exact same issue which causes intermittent shut down issues (Already tried another battery).
por
Esta resposta foi dada inicialmente para uma outra pergunta.
Before you go into the motherboard troubleshooting I would suggest that you charge the battery up to 100%, open up the phone, disconnect the charging port and proximity sensor and see if it still shuts off. If the problem is gone then re-connect the parts one by one until the problem re-occurs.
Pontuação 1
3 comentários:
Proximity already changed as it was broken, didn't solve the problem. I will try to unplug the charging port as well, thank you, will get back to you in about 9 hours.
Previously I'd thought that unplugging the proximity oughta fix it, it didn't, so I changed it, didn't fix it as well.
por
So far its still on, I'll see for a few days if it'll stay on like this, usually when batt gets around 70% it'll start turning off fast.
por
To be sure that it doesn't happen during this activity, open up a 10 hour long YouTube video and let it run for a while
por
My iPhone switches off when I lock it or when it’s go to sleep mode and for me to use it the screen must be on all the time please help
Pontuação 0
i would send it to the store you got it from and see if they can do anything about
Pontuação -1
1 comentário:
Haha I got it back in 2013, in Tokyo, I'm currently in Jakarta
sad(T ^ T)
por
Adicionar a sua resposta
Anon545454 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 119
