How to fix 1907FPc 19" LCD Monitor feet from tucking?
it is stuck in the bothom
Esta é uma boa pergunta?
RENX , Check to see if there are removable plastic caps covering up screws that could be tightened to stop the screen from tilting. I had a stand that would keep tilting down on me and I wrapped a large an elastic around the hinged joint giving the problem and it worked. Good luck.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Ao todo: 383
1 comentário
What is "tucking" and can you elaborate more on your problem
por Cameron
