Why is my laptop display black when I turn on the laptop?
The night before my laptop was working, and i shut it down. Then the morning after when i hit the power button the computer turns on but the screen stays black.
Esta é uma boa pergunta?
Daniel Castano , Listen to see if you can hear the hard drive running or not(could be faulty), if it is try a reset, unplug from power, and with the machine off, remove the battery and any attached external components.
Press and hold the power button for 60 seconds and release, put battery in and attach the charger. Try to power on.
If under warranty , have repaired under warranty.
Still no go, try an external monitor, if external works the problem is with the attached screen, may be faulty or bad connection. If external monitor does not work, the problem will be on board video/card or motherboard issue usually. Just in case try reseating the Ram as shown in the 3rd link.
2nd link is a trouble shooting link with more info., 4th link will show how to disassemble to check for bad components and loose cables,etc.. Also make sure to watch the video 1st link for how to diagnose your issue. If not wanting to diagnose and repair yourself, have a good local computer repair shop have a look, diagnose and estimate repair. Good luck.
https://www.youtube.com/watch?v=41Rxs3BU...
Guia
Nível de dificuldade:
Moderada
Guia
Fácil
30 minutes
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 694
