Ir para o conteúdo principal
Battery not charging after I changed it
Hi, I replaced my old battery with a new i bought here. After I replaced it, Iphone 5 turned on regularly and cherged til 40% . I went to sleep and let it charging, but at morning I found the iphone 5 turned off with 0% battery and now it is not charging anymore and doesn't turn on cause the low battery. I tried 2 different charging cables but it has not changed. can someone help me ? thx.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
What was wrong with the old battery? Was it that it drained to 0% and wouldn't charge or suddenly shut off at certain percentage or stopped working?
If it does not charge a flat battery then the U2 tristar charging IC chip needs to be replaced by someone that offers micro soldering.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Hello, change the charge socket first.
You can see how to change it from here
You can get it here
If not, you can try changing the battery
You can get the battery here
You can look at how to do it here
'''If this is not the case then the power integration is also a problem. If you can take a master repairer, you will do it easily.
Imagem de iPhone 5 Battery
Produto
iPhone 5 Battery
$29.99
Imagem de iPhone 5 Lightning Connector and Headphone Jack
Produto
$19.99
Imagem de iPhone 5 Bateria
Guia
Substituição da Bateria do iPhone 5
Nível de dificuldade:
Moderada
15 minutes - 1 hour
Guia
iPhone 5 Lightning Connector and Headphone Jack Replacement
Moderada
1 - 2 hours
Pontuação 1
3 comentários:
thx. the old battery was working wrongly. the percentage gone heavily down using it little bit, or shut off when it seems that was charged.
por
Ah then that's the battery most likely. Have you checked the charging cable if it plugs in fully with no gap and have you tried another charger port?
por
yes, i tried 2 different cables, and cleaned the dust but nothing happens. The strange thing is that after I've changed battery it was charging right, then I don't know what is happened because i found it turned off.
por
Adicionar a sua resposta
Gianluca De Dominicis será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 94
