Ir para o conteúdo principal
20-inch, 23-inch, and 30-inch aluminum LCD displays introduced by Apple in June 2004. Models A1081, A1082, and A1083 respectively.
20 Perguntas Visualizar todos
The display suddenly stopped working
Hi,
My 23' Apple Cinema display stopped working. It switches on but my mac (and other macs I tested) stopped detecting it. So no image... Any suggestions what I should replace/repair?
Thanks!
a-
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Shine a flashlight on it. If you can see images, then it means your backlight likely is broken. It may be cheaper to repair by changing the backlight.
por
Adicionar um comentário
1 resposta
If the display is not even recognized by the system, I would try listening if even the fan starts to roll. Otherwise I would go further checking the power voltages first. But yeah as @SW said You might as well quick try and see the Panel with a flashlight if you have a weak image without background lighting.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Alex Vincent será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 351
