Ir para o conteúdo principal
Repair guides and support for smartphones manufactured by Doogee.
71 Perguntas Visualizar todos
Phone not charging anymore
Hello, my X5 stopped charging. I've already tried other wall charger without any success. Problem is not the battery since it can be charged externally. If i buy and replace this (http://mobilespart.com/doogee-x5-doogee-...) will solve my problem?
Thank you guys.
Esta é uma boa pergunta?
Pontuação 3
11 comentários
Doogee s60 phone refusing to charge,
Phone ran out of power ,after the phone will not charge ore turn on.
por
my doogee x20 died and will not charge
por
My Doogee s88pro was working perfectly fine till this morning when it went dead and refuses to power on
I was using reverse wireless charge when it turn off completely. It is refusing to power on or respond to charging cable
por
@kankam any update?
por
I was asked by Dogee to ship it to their service centre. I did at a cost of about $50.00
Now that they are done repairing the phone but hav not shown any proof they are asking me to pay $37.5 for clearance. in fact Doogee official store in aliexpress has a poor service. i am really fustrated
por
Exibir mais 6 comentários
Adicionar um comentário
6 respostas
Pergunta mais útil
When you say you can charge it externally, you physically take it out and charge it in an external charger right? If that's the case, it's more than likely the charging port.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Hi I'm looking for doogee Y9Plus recharge port
por
That's right, Brian. Thank you so much for the answer.
I understand that it wouldn't be the problem, but do you think that a new USB plug charge replacement would fix it?
Thanks again.
Renan
Pontuação 0
1 comentário:
I brought of amozon doogee mix lite had it for Xmas and now it won't charge or come on you can't even take back of it
por
Have same problem, how are you charging battery externally?
Pontuação 0
Hi Renan,
Fixed a similar problem with Doogee Y6 phone with a new charge board. Your X5 is likely similar. The fix was reasonably straightforward, providing you have some soldering skill, see here:
https://forum.xda-developers.com/u/repai...
Best wishes and best of luck
Ron
Pontuação 0
I got a similar problem on my y100 plus and the technician said it was because of a problem in the circuit but I don't have any details about it. I think he just soldered something in the original board.
Pontuação 0
If So over phone make it very hit and no screen on what to do and what problem
Pontuação 0
1 comentário:
How to on back and what to make phone reduce hot and
por
Adicionar a sua resposta
renan_0491 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 20
Duração total: 10,538
