Ir para o conteúdo principal
Repair guides and support information for RCA-brand tablets.
1307 Perguntas Visualizar todos
My RCA Galileo Pro keeps dropping it's internet connection.
I've tried a back up tablet to see if it was a internet problem. It wasn't. The Galileo disconnects the from the internet for just a few seconds and it happens quite frequently. Really tests my patience! Please help! Thank you.
Esta é uma boa pergunta?
Pontuação 0
7 comentários
Have you tried the app "wifi manager" from the google play store?
por
Thank you for the reply to my question. I did install WiFi manager with high hopes. Unfortunately, it was not compatible with this tablet. Thank you for the suggestion.
por
It turns out all I needed to do to fix this problem was simply change the channel from "auto" to anything else from 1 to 11. I hope this helps anyone else who might be having the same problem.
por
What do you mean by channel...how do I find it.
por
hey my RCA tablet had a problem it's WI-fi cuts out and it takes like 5 or 4 minutes to come back plzz help
por
Exibir mais 2 comentários
Adicionar um comentário
5 respostas
Solução escolhida
Hi,
Not sure if you have these options but go to Settings > Wireless and Networks > WiFi > tap menu icon (3 vertical dots upper right corner and tap Advanced.
1. Keep WiFi on during sleep - select Always
2. WiFi Optimization - disable
Esta resposta foi útil?
Pontuação 4
1 comentário:
Thank you for your reply unfortunately this did not work for me as either I don't have, or I could not find WiFi optionization. Thank you though and have a great day.
por
Mine always drops the WiFi, I end up have to unplug my router constantly to get it to come back on, but it doesn't take long then it drops again. I love how big the screen and detachable keyboard are but I am hating this tablet cause of the WiFi problems! Its weak, have even used another tablet to get to my WiFi router to put the pin in and nothing works, this tablet sucks!
Pontuação 1
I always keep my phone on the end table while I'm using my RCA tablet, and I was having a similar problem. In my case, I have a mobile hotspot which provides internet access to my tablet. I resolved the issue by turning off the wifi searching device on my phone and the phone's data service while using the hotspot.
Pontuação 0
download a live wifi meter from playstore and while viewing the live data shake ur tablet if it drops try disconnecting keyboard and retrying it. if i use it without keyboard it works great and never looses wifi….
Pontuação 0
One has to wonder that it may not be so much the problem with cheesey wifi connection but, where the server is located. For example one can only assume that when playing a game and it's online but the server is 4000 miles away in another country is it possible the router and internal wifi can have a poor connection or poor handshake signal?
Pontuação 0
Adicionar a sua resposta
Audra Kruger será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 6,940
