Ir para o conteúdo principal
The fourth-generation Surface Pro tablet, released October 26th, 2015.
20 Perguntas Visualizar todos
After screen replacement, Surface Pro only boots when plugged in
After the screen replacement the device is not starting without power supply. But with the power supply, it is showing that the battery is charging, and the battery report seems to be ok :-/
Can anyone help me?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
Solução escolhida
我的电脑一样的问题,自己修过以后就只能插电使用。返厂维修发现主板出问题了。这个很难判断哪里出了问题,很可能是静电打到了上面。自己维修一定要防护静电,带上防静电手套
Esta resposta foi útil?
Pontuação 1
1 comentário:
My computer the same problem, after their repair can only be used after the plug. Depot repair found the motherboard problems. It is difficult to determine where a problem, it is likely to hit the top of the static. Own maintenance must protect against static electricity, bring anti-static gloves
por
Adicionar a sua resposta
Waqas Ghaffar será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,135
