Ir para o conteúdo principal
Burning smell coming from hardware?
Hello, I have removed the display from the mac and unplugged from system, due to the backlight no longer working. Then when I plug it back in and power on the display the screen works but the backlight doesn't turn on and the casing smells like it's burning. Almost like when a capacitor continues to burn in a TV.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Keep the computer off and return it for repair. If you are local to an apple store, bring it in there.
Keep in mind that something as simple as a hair that fell on a heating coil and closed within your computer could produce this... or it could be a warning of imminent fire.
Problems with your magsafe and excessive heat or burning smells should prompt you to be sure to keep the device off.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Mag-safe on an iMac?
por
Adicionar a sua resposta
Ryan Handy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 220
