Ir para o conteúdo principal
Released in March 2013, identified by model number S500CA-SI50305T
Will I need a new windows 10 key?
I bought an asus s500ca without a hard drive I'm hoping to use a usb boot I downloaded from Microsoft and I was wondering if when I boot it up with this usb will I need to enter a new product key?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
What operating system originally came with this laptop? Both Windows 10 and 8 in later models had keys embedded in the motherboard. When you install, it will self activate with those keys.
Esta resposta foi útil?
Pontuação 5
1 comentário:
I'm here to second that. I work in PC repair and if it is a Windows 8 or above PC with an embedded key it should just activate.
por
It should let you skip applying a serial code. It will notify you continuously though. There are some sites that give out codes (cant post here). Be wary on such sites as many are a bit sketchy
Pontuação 0
Adicionar a sua resposta
Brad será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 638
