Ir para o conteúdo principal
O B15 da Caterpillar é um smartphone baseado em Android com um design robusto e durável e uma autonomia da bateria bastante longa.
Help to turn on
My cat b15 have problem with power button is not working . My question is can i trun on the Cat without power button
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Hi, Herlit
Unfortunatly the only way to get that device to boot is to switch the powerbutton there are no other ways to boot the device unless USB debugging mode was enabled in that case you could boot it using odin
Esta resposta foi útil?
Pontuação 0
Fortunatly, stephenthorodso was wrong. There is a way to boot CAT B15 Android phone that is turned off and power button is broken.
Here are the steps:
1) download and install "Minimal ADB and Fastboot" console application for Windows
2) Connect your phone with PC via USB (it will just show battery charging, but don't worry)
3) Start "Minimal ADB and Fastboot" from Windows Start Menu -- it will open Command Prompt
4) Take out the battery from the phone
5) Keep pressed "Volume Down" and the button between Volume Down and Up (however it is called)
6) While these two side buttons are pressed, put the battery back into phone
7) The phone will enter the "Fastboot mode" (you'll see small text at bottom-left corner of the screen)
8) Now, back at the Command Prompt
- you are probably already at fastboot installation path: "c:\Program Files (x86)\Minimal ADB and Fastboot" - if not, go there: cd c:\Program Files (x86)\Minimal ADB and Fastboot
- now, to make sure your USB connection with the phone works well, type:
fastboot devices [enter]
you should get something like: mt6582_phone fastboot
9) now type: "fastboot continue" [enter]
wait 10-15 seconds and you'll see your CAT B15 booting into normal Android!!!!
(just worked for me and I'm super happy)
Pontuação 0
Adicionar a sua resposta
Herlit será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 30
Ao todo: 1,237
