Ir para o conteúdo principal
A 5", 3 pound personal random orbit sander made by Porter Cable and released in 2010
4 Perguntas Visualizar todos
Motor runs way too fast but has no power, stops when in contact with b
Motor winds up faster than normal but has no power. Stops as soon as it has any resistance. I can still hear the motor humming. Brushes seem to be free moving.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
@cajamadi ,Peter, Sounds like the center hub retaining bolt may of came loose or hub may have cracked/stripped not holding tight on shaft. Disassembly guide link below may help in diagnosing your issue with the sander. Good luck.
Porter-Cable 382 Fan Replacement
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
peter será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 248
