Ir para o conteúdo principal
Released in February 2014. A Garmin manufactured GPS multi-sport training watch with illuminated display.
13 Perguntas Visualizar todos
Start/Stop Button Not Working
Start/Stop Button Not Working. All other button function.
Can the start/stop button be replaced?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
@alistair , Alistair, Use the disassembly guide below to take your watch apart and clean the buttons perhaps if need be then you will have access to change buttons. Use a soft cloth or Qtip dampened with 90% Isopropyl Alcohol to clean around the buttons and contacts. Good luck.
Garmin Fenix 2 Motherboard Replacement
Esta resposta foi útil?
Pontuação 2
Hi, i have the same problem on my GARMIN Fenix 3, You think the solution is the same ?
Thanks
Pontuação 0
Adicionar a sua resposta
Alistair será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 23
Duração total: 14,477
