Ir para o conteúdo principal
A 2-in-1 laptop/tablet with full 360° folding capabilities. Contains a 2.00GHz i7-5500U processor and was released in 2015 with model number 80JH000WUS.
20 Perguntas Visualizar todos
Pressure on Laptop Hinge causes screen to freeze and not turn off
For a while, every time I've put any pressure on the center of the hinge of my laptop, my laptop screen freezes, the computer gets warm, and the screen only turns off if the computer is forced to shut down. Sometimes, I'll just be sitting and using the laptop and it'll freeze without me realizing that any pressure was put on it. Lately, it's become more sensitive and I've been wondering if anybody knows anything about this: Is it repairable, and, if not, what can I do about it?
Thanks!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
It's a connection issue on the LCD LVDS cable that provides connection between the monitor and the logic board a.k.a the main board of the laptop.
Cable is either loose or damaged most likely. If it is damaged the only way to get it working again is to replace it.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Thank you very much... Do you think that this is what I would need? http://www.waresphere.com/store/lcd-lvds...
por
Adicionar a sua resposta
Wavejump será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 1,899
