Possible antenna line defect?
Looks like one of the antenna lines on my iPhone appears to be not much -inline- with case, it feels like a small bump. Is it normal? Did you see something similar?
Esta é uma boa pergunta?
Such slight misalignment is negligible.
The bump is likely caused by internal stress or heat during the machining process.
Esta resposta foi útil?
I think it is normal, my 5s used to do this a tiny bit too. Even if it is not it should not do anything bad.
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 191
